The plot sickens ! drilled a nice hole for the bolt extractor....started turning and lo and ###### behold teh extractor has snapped in the hole!!!what do i do now? only thing i can think of is to drill out the hole(thread as well ) and get a helicoil kit and do it that way....can any of you surfaholics foresee any problems with doing this or maybe one of you wise old sages can think of another way...p.s. once this only problem is solved i promise i,ll become a fully fledged subscriber. cheers all . I,m off to find the cat to give it a good kick....
fu***ing idler bolt. HELLPPP
Originally posted by Bluebirdsurfer View PostThe plot sickens ! drilled a nice hole for the bolt extractor....started turning and lo and ###### behold teh extractor has snapped in the hole!!!what do i do now? only thing i can think of is to drill out the hole(thread as well ) and get a helicoil kit and do it that way....can any of you surfaholics foresee any problems with doing this or maybe one of you wise old sages can think of another way...p.s. once this only problem is solved i promise i,ll become a fully fledged subscriber. cheers all . I,m off to find the cat to give it a good kick....
Hi Stevie, are you talking about the 3 bolts that hold the idler arm to the chassis. I have took 3 or 4 of them off and the bolts have a nuts on the far side of the chassis. If the head of the bolt has come off then you can just knock it out, no need for drilling or helicoils. Thats if I am thinking of the same idler arm bolts.
chrisxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
The extractor is made of hardened steel. If it is still wedged in the hole you drilled (highly likely) you will not be able to drill into it again.Originally posted by Bluebirdsurfer View Postbehold teh extractor has snapped in the hole!!!what do i do now? only thing i can think of is to drill out the hole(thread as well ) and get a helicoil kit and do it that way.....
Do what Nev said - try and get someone to weld a bolt onto the end (if there's enough sticking out) and undo it that way.
Otherwise you do have a problem. See if you can get a centre punch and tap it around.
Pity you fell asleep = could have called up this afternoon and had a looksee.Another member of the 'A' team
wot a palaver
the only part of the bolt left in the hole is the threaded part(about an inch) into that is jammed about an inch of (useless extractor) so from the face of the hole to the extractor is a gap of about an inch. I,m going to have a prod at it now for an hour, if i don,t get lucky then the cat is having another kick! will update in about an hour. cheers.STEVIE J
