are they the same
  • are they the same
    are the non efi and efi basic engines(block and head) the same??????
    I believe the blocks are slightly different so that there's somewhere to plug in the additional sensors for the EFI.
      aye there's a crankshaft position sensor somewhere on the EFI, not sure about any other differences
      =SOLD UP!=
        will that make any difference if an non efi goes into and efi truck?
          YES TPS missing as mentioned before
            TPS is on the throttle housing not the block. EFI has a Crank Sensor just behind the fuel pump and a Coolant Sensor behind starter, just below the head roughly between cylinders three and four.
            Nev
              Yes. It will never run properly unless a crank sensor and a coolant sensor is used. The ECU needs these.
              Nev
                OOPS
