Auto Manual Gearboxs
  • Auto Manual Gearboxs
    Is The Engine The Same In Both Auto And Manual, Only That Someone Has Told Me A Manual Gearbox Will Not Fit On To A Auto Engine And Vice Versa? Is This True Or Is This Bloke A Complete Muppet Any Help Would Be Greatful
    you can change them but you need things like th ecu and other stuff
      If you're thinking engine swap, then you should be ok AFAIK, the engines are the same,
      Rob
      Still working for the man!
        Yeah I Was On About An Engine Swap Into My Auto The Rings Have Gone Amongst Other Things Cheers
          are the bellhousings & flywheel not different? Mind if you're swapping the engines in shouldn't be to hard to swap them over too.
          I'm probably wrong anyway.
          =SOLD UP!=
