Need a hose.
  • Need a hose.
    Hello all,
    Do any of you have a spare hose that goes from the air filter to the plastic pipe on the top of the engine as mine has split.
    The part no; is 17881-54340.
    My surf is a 93 2.4t with the silver top EFi engine.
    I Live near Warrington so I can travel anywhere in the Northwest within reason,
    Thanks in Advance,
    Dave.
    PS...the cheaper the better!!
    Try Rough Trax on 0117 986 9065, they do replacement ones. I have a cracked one too, but not for much longer
    There are 10 kind of people in the world, those that understand binary and those that don't.
    'There's no place like 127.0.0.1'
      Originally posted by Oli
      Hello all,
      Thanks in Advance,
      Dave.
      Hi Oli I have just repaired a convoluted hose with a piece of inner tube.
      The size of the inner tube 110/90 /10 (Butyl rubber)
      If you want to try this repair you will have to support the tube internally with something round. I used a brasso tin. Use washing up liquid as a lube.
      It aint easy but with persiverance it can be done.
      Oldone
      Still rolling and waving
        Split Hose?
        I just used super glue to fix it, just make sure its dry before yah put it back on.
