Help needed
  • Help needed
    Hi, sorry if the question seems silly but I have no knowledge about the Hilux Surf. The Surf SSR 1992 has the spare wheel underneath, how to pull it out if I need to change the wheel? Also which generation is the 1992 model?
    Thanks to everybody.
    John Neto
    John Neto
    the wheel winds down, the surf is a 2nd gen 92
    [size=5][/size]
      John Neto
      You should have a long bar - located underneath the back seat (passenger side) and a handle in the tool roll. Insert the long bar through the hole in the rear bumper (at an angle if it is a widebody towards the passenger side). Locate the hooked end in the slot in the winder - you'll need to move the bar around a bot to find it, then wind down the wheel with the handle on the end of the bar.
        Thanks Andy
          Thanks Ian
