timing marks
  • timing marks
    has anybody got a picture of the timing marks on a 2.4 as i will be changing the diesel pump shortly so any help would be great.
    cheers shaun
    NO LONGER A SURFER NOW DRIVING A LEXUS
    The cam shaft one is at the bottom of the pulley the pump amd the crank are at the top of the pulley
    www.daemon4x4.org
      thanks ian i think veg oil has killerd the pump so i will have to fit another in the next couple of days
      cheers shaun
        cheers shaun
        Remember to tighten all the pipes after and only crack the injector couplings if you have to ..........Beware damaging the diesel return pipe and injectors comming unscrewed
        www.daemon4x4.org
          Trust woodzie as i beleieve he has already done the above said change. And the injector bit
          Without Surf And Unhappy
            It's alive .........thanks to Surfenstein
            ALL PRAISE SURFENSTEIN
            www.daemon4x4.org
              This write up has a very clear full frontal (oo, err) shot of the timing marks
              http://toyotasurf.asn.au/techsite/timingbelt.htm
              check out the rest of the site for lots of info
              http://toyotasurf.asn.au/techsite/24table.htm
              and this part of the site for mods and stuff
                cheers guy for the replies not looking forward to doing it but needs must!!!
                cheers shaun
