Engine manual 2.4td EFI
  • Engine manual 2.4td EFI
    Hi all, new here, im after a Engine manual for the above out of a 1991 ssrg surf.
    please advise where i can get one, and if possible a downloadable version would be best.
    Thanks.
    Col
    check matts download site http://forums.bauchan.org/portal/downloads.php
    or
    codlords site at http://www.showmesome.info/hilux/
    the 2.4TD Efi engine code is 2L-TE so you can be sure you're looking at the right stuff.
    =SOLD UP!=
      thanks
      cheers for that, - useful site! stuggling to download tho, - says no available slots
        it's a ftp site with max # of connections limited, use an ftp client such as filezilla (linked to on that site) and it'll get on within a few hours if you just leave it to keep retrying
        =SOLD UP!=
          Aye, as Nero mentioned, a ftp client can be set to retry every half hour or so. The ftp site is at: ftp.bauchan.org
          Edit: Btw, it's the 2LT manual you want. There isn't a specific manual for the 2LT-E. The differences between the two are very minor, however.
