Hi all
I have a 1992 import 2.4 Surf and the rear electric window doesn't go up all the way into the seals without help from my hand, any idea's on why and how to fix??
Also the swith for the rear window that is in the cab no longer works, is this just the switch or are there other reasons? I have taken the back carpet & panel off and notice a micro switch which the earth wire (black) has snapped off, is this anything to do with it??
And finally....the rear door doesn't come down without me having to pull the left side wire and doing it manually, is this the cable that needs replacing or is there some thing else I should be looking for??
It has central locking if that helps.
Any help with these matters would be greatly appreciated.
Regards
The Badger
Regards
The Badger
