Right the injector pump is in cam belt on .....diesel to the injectors.....it's trying to fire but not quite there......we suspect that the pump needs to be advanced slightly .......IS it top towards the block to advance and away to retard or the other way round , atm the lines all line up the only difference is that the pump is from vince's truck , and yes it has all the same serial no's .
More problems ......
