just tryed checking the fault codes and i got nothing from the engine management light. but i did get the glow plug heater light flash 4 times then 7 what dose that mean as i thought all faults where on the engine check light
faults
mines a 89 non efi same as yours and my glow plug light flashes aswell. we don,t have so many sensors so the fault code list on here isn,t relavent to our cars.
i had broken wires on the back of my engine coolant temp sensor (the one above the starter) and that came up as 2 flashes of the glow plug light.
also had a blocked pipe going to the turbo sensor that came up as 4 flashes.
on the efi fault code list it says 2 flashes for engine temp and 4 for turbo so i have had a play around in the past and ours are deffo the other way round.
cant help with 7 though
