Indicator Beep
  • Indicator Beep
    Got a weird problem with the truck after Baldhu (which was a great laugh).
    With the headlights off, if I indicate right, there's a beeping noise coming from the back of the truck.
    With the headlights on (side, dip or full) the noise doesn't happen.
    I'm guessing an earth-leak somewhere, but I thought I'd check with the forum... see if anyone's had the same.
    (I got off lightly... this and the missing fog-light is all I got for nearly turning the truck over in the mud)
    Go spray a load of WD40 into your towbar electrics socket, that should fix it
    it's in me shed, mate.
      Ah! Didn't remember that one... cheers!
        Then gob it all up with vaseline or electrical grease.
          That did the trick! Cheers!
