my cylinder head cracked and have had some good advice on here so hopefuly one more piece of advice please.
right i have replaced everything with genuine toyota parts the head, water pump, t stat, head gasket, crank pulley, rad cap, air pipes i can run the engine with the rad cap off theres not an excesive amount of pressure i can rev the nackers of the engine and no water comes out but if i drive it 100 yards water $$$$es out of somewhere near the passenger side wheel arch ive seen it when im driving i drive up to the next street no more than 50 yards away pull in reverse back there is loads of water all over but when i pull up nothing is leaking it is doing my head in plus where the hell is the water tap for the block it says rear left of block but im buggered if i can find it have flushed out engine best i can but if i could put my finger on this it may help oh and i know its stupid but the t stat cap do i screw it as far as i can or do i just turn it to the first recesses
cheers
dirty fingernails
cheers
dirty fingernails
