Hi Guys,
Have just put my new head on, and put the timing belt on. I didn't need to have the crank pulley '1 tooth out' as has been mentioned on here a lot, and am now wondering if my tensioner is not tensioning enough ?
How much play should there be on the belt between the fuel pump pulley and the camshaft pulley ?
Also should I just rely on the spring to tension, or do I have to lever the tensioner slightly to get it tight enough ?
Cheers,
Rob.
Edit - I turned the engine over 4 times after fitting it and all the marks aligned correctly btw.
Cheers,
Rob.
