re engine help
  • re engine help
    Mates: it's an automatic 91 surfr.ln130. the fuel pump was recently changed. the computer shows no error codes...yet there seems to be a fuel starvation?..at high speed...ok..but in traffic....low rpm...cutsoff...and then I restart as usual...had similiar problem before pump was changed...this was done as a means of localizing problem.any info would help..thanks
    has the fuel filter been changed?it sounds like you have air leaking into the fuel system from some where.
    www.overfab.uk
      I had EXACTLY the same issue.
      Tried tightening the fuel pipes on the filter, replaced the filter, had fuel pump done etc etc etc.
      No one knew how to fix it, including three mechanics (one a Toyota specialist), all the guys on here, a fuel pump technician guy (who made the problem worse).
      Good luck mate, I solved my problem - by selling the daft lump!!!!!
      www.myspace.com/conandoomconan
        Get a diagnostics check done, the info is on here, do a search.
          Try tightening the screw on top of the black button on top of the pump primer........
          That cured the same problem for one of the lads on here (he just emailed me).
            has it been stud a while at all
            i had the same thing on a diesel engine (not a surf but was import digger)
            the diesel they use over they is not like ower (so i was told)
            when the digger had been stud (for 2 years) over time water condences in the tank from the diesel (i did not beleave it at first) but we droped the tank off draned all the fuel put it all back on changed all fuel filters primed it up still runs perfect to this day all a long it was just water and air traped all over the place messy job but worth it (you can get car cheap with this same problem
            well my surf been stud for 3 years i will have it fully clean fuel pips filter tank
            just in case
              try changing the fuel lines to clear hose that way you can see if it is drawing air in or spray all fuel lines, pump, filters,ext, with wd40 or some highly flammable aerosal , if the engine revs automatically you know there is a leek,
              hope that helps
