Hi guys & girls,
I've tried all sorts of things to settle the surf down to no avail.
Checked vacuum hoses against Jotto's
unplugged re plugged everything
redex'd the fuel pump direct
Bled thru the fuel filter
reset the ECU
Ran diag's on the ECU - code 1 - all is well !?)
The car has a lumpy / missing sound from the exhaust and the ehgine feels lumpy / is noisier than it should be So I thought I might change the injectors.
Is there a procedure / or some pictures / hints I can have off any of you ?
Thanks in advance
Jim
reset the ECU
Thanks in advance
Jim
