Hi All,
Am in the middle of doing a (stevo supplied) head replacement on my '93 2.4TD. I've removed the turbo / exhaust manifold side completely, and nearly all the pipes etc are done and labelled on the inlet side. Also removed the cambelt etc at the front of engine.
I want to leave the inlet manifold on the head until on the bench, as recommended several times on this forum by both TonyN and Stevo, and my question is about the fuel injector supply pipes and the glow plug supply bar.
Wheres the best place to disconnect these so I can finally get the head off ?
Thanks,
Rob.
Thanks,
Rob.
