Hello
I get an noise when the engine is warm like a squeak or squeal when i go over a slight bump in the road or accelerate hard it sounds a bit like a belt noise but it’s not i changed the belts and they are all ok now. any ideas ive given the prop and uj`s a good grease noise still there. could it be the crank pulley?
If i roll the car down a hill with the engine off and in neutral the noise is still there but only when the car is warm!!!
