veg oil
  • #46
    Forgot to say, im a 100% veg man (diesel over night) Theres no lasting damage you can do if the oil is heated a bit(once youve changed your seals that is) Will always continue to do so, as I dont listen to scaremongery.
    Without Surf And Unhappy
    • #47
      i cracked open the water trap drain the other day , and the oil/derv that spilled out was hot on my hand , so it looks like it gets hot simply flowing around the system anyways , its how long it takes i suppose to get warm/hot.
      can't imagine it to take long though
      • #48
        i fitted a new pump seal and its leaking again? One last fix then back to derv until i do a long distance haul
        What comes around goes around!!
