Hi all,
Need some help - my 2.4 TD truck has recently developed a problem with the idle speed. The idle speed is normally 800rpm however when idling, my truck idle speed intermittently jumps to 1000rpm. This change in idle speed is sometimes accompanied with a 'clunk' however not always. This also does not look to be related to the idle-up button as this takes my idle speed to 1500rpm.
My engine check light has been coming on intermittently also and appears to be related, however I cannot be 100% sure this happens when the idle speed changes, as it happens when driving.
I don't have a clue where to start looking and if I put it into a garage then no doubt it will not happen when the car is in.
Anyone got any ideas what the problem could be?
Still have problems with idle speed but I can live with that for the time being.
