hi all,need some help.
have just replaced my head/gasket/bolts etc etc etc,had to put the batteries on charge where she had been off road for a month and theyve gone flat,they were on fast charge for about 10 hours yesterday and turn the surf over fine,the trouble i have is that i dont appear to be getting any diesel up to the injectors at all.ive primed the system and filled the fuel filter up! ive tightened three injectors up leaving one open whilst the mrs turned the key for half a minute at a time but getting no where except flattening the batteries.also although im only turning over for a short while the top hose seems to pressurise quickly,i used decent payen bolts and gasket could it be an air lock causing that much pressure or could i have cracked the block
i did put a flat rule on the block to see if it was distorted but didnt notice anything like cracks etc ...
any help /advice appreciated cheers
,what do you reckon about the hoses pressurising...i dont quite understand the 'burping the cooling sysytem' thing are there any other ways people have had success with..
