While driving up the motorway the other day I noticed white smoke (diesel fuel running onto the exhaust) behind the surf, pulled over and found the rubber O ring at the bottom of the fuel filter had pushed out of the side again.
The O ring is the one at the bottom of the filter; this has happened twice now and wondered if anyone else had had this problem? Both times it’s been on long motorway runs. It’s as if the O ring expands and pushes its self out of the gap between the filter and the plastic bottom bit with the water tap.
Any ideas why this is happening?
