good evening
to cut a long story short my surf when idleing sometimes smokes its a grey smoke smells a bit like oil and when a move off it dissapears it only turns up now and again i changed the oil the other weekend and it only seems to have done it since then. I have used the oil type that i have always used 15/40 diesel oil just wondered if anone else has come across this problem. tommorrow i am going to have a look at the intake pipes to see if there is any oil in them and give them a clean also im going th have a quick check to see if i may have overfilled the oil by mistake apart from that my only other idea is the turbo seals any suggestions on this would be greatly appreciated
Chris.
Chris.
