out of gas
  • out of gas
    yeah i ran out of gas lastnight
    and a friend of mine told me that there is a chance there could be air in the fuel line. is this just older models then a 91 or do i have to bleed my lines?
    If your talking about a Toy diesel motor, it won't need bleeding, pump the primer on top of the fuel filter till it goes hard, you may need someone else to crank it while you're doing it if the pump is weak, but thats about it.
      the injectors on yours are self bleeding so just pump like tonyN suggests.
      [SIZE=4]Benjami
        I'd remove the fuel filter and fill it with diesel and then refit, then pump, (bit of a limp wristed jessie)
        cheers
        dinna say eh?....say fit?
