part No.1
Hi all
I have a 90 Hilux Surf 2.4 TD with 120,000 miles and have been losing / using coolant. The temperature gauge reaches half way and never ever climbs further. I have to top the reservoir tank from empty after about 400 miles.
No obvious signs of leaks / drips etc.
Any ideas ? If not I guess it'll be a garage trip.
Chris
after some info from the group, I had a good look at it and was alarmed to find that the tube for expanded coolant to flow along from the engine into the plastic expansion chamber is not long enough to reach the bottom of the chamber (only half way). So even though I have been filling up with fluid (to the full level on the expansion chamber), the engine as it cools could only suck in a small amount of fluid until the fluid level drops to the bottom of the hose and the hose is out of the fluid, so in theory the engine coolant level in the engine could be very low but the expansion bottle shows half full. Are other surfs this way ?
will keep my eye on it and get pressure check at garage, will look for longer hose also.
strange how the temp gauge never goes above half way, will get that checked too
Chris
Hi all
Chris
Chris
Same has just happened to my 1992 2.4TD. In an attempt to save money temporarily I have put Radweld in the radiator - problem solved! Not loosing coolant anymore. I'm sure this is a v.temporary solution - but they dont call me Mr. Bodge-it for nothing. (in fact they dont call me that)(but probably soon will) Cheap experiment though!
Fingers crossed nothing else goes wrong... Alex
