The hi -lo box still wont shift, even in P or N. Only way to get the transfer box to engage is to turn the engine off. This morning, I dropped it into lo and reversed a few yards then put the main box in P. Couldnt get the transfer box out of lo! tuned the engine off and with a bit of tuggin I managed to get transfer box back into hi, but no matter what I do it wont go into lo without grating the gears unless i switch off the engine. The 4WD selector buton works fine BTW, as does the the transfer box once I get it into gear. its just the actual problem of shifting. Whats the correct procedure, am I doin it wrong or is something busted?
BTW thanks to all for the replies to previous postings, your all brill.
