I have a 2.4 turbo 1992 surf which overheated and consequently cracked the head. I had another engine which i took the head off,had tested and skimmed then I fitted it myself. Since getting it going i've found it doesn't start as well as before,there's a slight miss when cold on low revs and it doesnt have as much power as before although it has improved after a couple of short runs. Does anyone have any suggestions?
Power Loss
Originally posted by Phil DaviesI have a 2.4 turbo 1992 surf which overheated and consequently cracked the head. I had another engine which i took the head off,had tested and skimmed then I fitted it myself. Since getting it going i've found it doesn't start as well as before,there's a slight miss when cold on low revs and it doesnt have as much power as before although it has improved after a couple of short runs. Does anyone have any suggestions?
Hi Phil.
If you scroll down to the bottom of this page there are 5 threads to do with power loss take a gander thru them and see if anything in them helps you at allhttps://www.facebook.com/groups/henpals/
http://www.yotasurf.co.uk/members_pa...evo/index.html
Have a look at this and give steve a call, He's your best bet. Good luck. Oh and of course, Welcome too.http://www.apspropertyfix.co.uk/
