turbo pipe fitting
  • turbo pipe fitting
    how hard or easy is it to refit a new turbo 2 manifold pipe this one
    http://www.toyotahilux.com/index.php...id=135&vid=712
    zacco
    The easiest way to fit/remove it, is to loosen all four hose clips at both ends of the silver tube.
    There will be swearing, oh yes!
      What do you use to compress the clips?
        Fingers, unless you're a gurl!
          Yeah, but you're one of the first genner's, remember.
            <girly mode = on>
            I used a mole wrench to do the clips on mine.
            </girly mode>
            You should be able to change the pipe in under 5 minutes, it's pretty easy. As mentioned, easiest way it to undo the metal pipe that goes over the engine at both end, and take that out.
            Paul </Slugsie>
            Immortal.so far!
              mine has two jubille clips ..a good start to pull off first i agree ...
              im not mechanicly minded
              so theres two jubille cilps holdin the rubber pipe ...then theres the metal pipe held with 4 hose clips ? remove that then reassemble in reverse?
              zacco
                Yeah, sorry I forgot what they used to be. I replaced all my original hose clips with shiney new Jubilee ones.
