towing the caravan
  • towing the caravan
    hi there i have a manual 2.4 surf do i ned any mods to the coolng system when i tow my caravan, the caravan is 21ft and weighs 880kgs
    cheers:
    SILENCE........................I ... kill you
    cheers:
    Jon look in the basement where tin snails belong...http://www.hiluxsurf.co.uk/forums/showthread.php?t=2931
    www.daemon4x4.org
      me's been there many surfs dont have the problem but the square plate and spots might be a no no need to keep the airflow
        Bonnet vents then
        www.daemon4x4.org
          Bonnet vents then
          i know a car with some of them he he.that would be a good idea wiil have to look into that one
            ATF cooler. Or try flying, it's ever so much faster
              tried flying not to keen rather be dawdling down the road to the beach,much cheaper
                It'd be a b@st@rd to attach the caravan to, though.
                  My vehicle has no mods to the drive train, and tows a 1 tonne trailer without problem. With regard to air flow restrictions I have 4 x 6" spots fitted to the factory A bar and as yet this hasn't caused any problems. However my number plate is fitted beneath the A bar so doesn't effect airflow to the rad at all.
                  Gone from 4x4 to 1x2
                    change the plate and take off the spots?
                      Jon add to your profile that its a manual then you won't get atf cooler comments
                      www.daemon4x4.org
