Evening all, Just changed the glow plugs on 2.4 ssr-g on a k.Problem is i've split the inlet pipe to the turbo,presume this is only air inlet as it seems to run to the air filter.Front of turbo turns 90 degrees to the right. Anyone got an easy solution or know the part number as my local dealer is about as much use as a one legged man in an ass kicking contest.
cheers Dave
cheers Dave
