Hi. I've had a new head put on the surf and since then I've been keeping an eye on water levels.
Once i top up water under the rad cap to the top, I then drive a couple of hundred miles. When the engine is cool, I check the water level and no water can actually be seen under the rad cap. I have to put in another 20/30mls before it reaches the top again. I'm wondering if this is a problem or whether the water has just been put into the expansion tank.
Many thanks.
Many thanks.
