No hot air.
  • No hot air.
    My heater fan switch on the dash has died so no demist on these orrible damp & cold mornings. Has anybody else had this problem & if so how did they sort it?
    Ta.
    Nick if you scroll down to the bottom of the page there are 4 or 5 threads that may cover what you need to know.If you have already seen them then vince will be along to give advice
      Cheers Ritchard but them threads dont help, 'tiss my slider switch wots pining for the fjords I was going to simply fit a on/off switch but this wont do.
        There's a fuse and relay up behind the glovebox for the heater. If they're OK, then the operating cable has come off the slider switch.
          I will check the fuse and relay tomoz & hope for the best but the fan switch feels "lumpy" when sliding and it was always hit & miss trying to get it to switch the fan on high, is this switch changable or do I need to swap the complete heater control unit?
