Glow Plug And Starting Question
  • Glow Plug And Starting Question
    Hey Everyone I Have A Question With My Surf!!!
    Its Really Hard To Start Out Now That Its Cold It Cranks Over And Nothing Happens. I Let The Glow Plug Light Go Off Then I Try It For A Few Seconds Then Stop And Do The Process Again!!! Anyone Have Any Answers Why This May Happen I Think Its The Glow Plugs My Im Just New To Diesels Haha Any Info Would Help
    P.s. If It Is The Glow Plugs Does Anyone Have The Toyota Number I Live In British Columbia Canada And No Hase Heard Of These Beauties!!!
    Thanks For Everything
    Rob
    Give these guys a ring and see if they will export them to you. If not let me know and I can get some and send them on.
    http://www.toyotahilux.com/
    You don't say what truck/engine you have.
    If its a 2.4, make sure your letting the glowplugs stayo n long enough, ignore the light, and wait till you hear the relay click off, then try it. It may just need two goes on the glows if its really cold.
    Make sure you have power to the glowplugs first, if not check the fuse and relay.
      Originally posted by TonyN
      If its a 2.4, make sure your letting the glowplugs stayo n long enough, ignore the light, and wait till you hear the relay click off, then try it. I may just need two goes on the glows if its really cold.
      Relay click. That's the girl method. Wait until you hear the beep if it's
      a 2.4.
        haha nice thanks!!!!!! thanks for the tip haha ill try not to be a woman about it
          i let mine beep three times in a row starts first go and no erratic idling anymore...sure the batteries aint liking it much though as i only live 2 miles from work .... but i love driving my surf sooooo much
          DONT RUN WIV BIG DOGS IF U CANT PI** UP TALL TREES
            Canadian!
            Hey buddy,
            I'm also a new surf owner. I live in saskatchewan. I'm running into the same issues with parts. But your in luck... Glow plugs...
            the genuine toyota glow plug
            part # 19850-54090 ~ $40 a plug
            aftermarket NGK plug
            Y-715R ~ $20 a plug
            Cheers,
            Erik
              check out this link for some useful info
              http://www.hiluxsurf.co.uk/forums/sh...d=1#post242107
                fixed it yet?
                Are you getting a puff of diesel out of the exhaust when trying to start??
                If not make sure the primer pump is working by pumping the top.If it doesn,t get harder to press after about 20 pumps then the diaphram is probably split allowing fuel to drain back to the tank!!
                Also check fuel cut off solenoid / leaks / fuel in tank is diesel!!!
                  Hi Everyone,
                  I'm also having starting problem with my 1992 surf (originally from Japan). Fuse is OK, glow plug relay is also ticking. Just want to ask, how long is the normal preheating of the glow plugs? I observe mine to be just approx 3 secs. Hoping for your comment.
                    Wow, digging up a 3 year old post?! There's a currently running thread on glow plugs and starter issues, with plenty of good info in it: http://www.hiluxsurf.co.uk/forums/sh...ght=glow+plugs
                    Most of what you need is probably in there.
                    Andy
                    http://www.surfingafrica.net
