Rear Suspension
  • Rear Suspension
    My 1989 2.4 Turbo Deisel Seems To Be Sat Too Low At The Back ,so Low That I Cannot Get The Hitch On My Boat Trailer Low Enough To Get Onto The Tow Ball .its Also Showing Alot Of Arch At The Front.its Currently Stored Off Road And I Am Not Using It,but I Need To Get This Remedied Before I Export It To France In The Spring.anyone Got Any Ideas ?
    Thanks,
    James.
    ARSe end sag is a common problem on surfs, new shocks and springs, milner's springs are cheaper than roughtrax, and procomp shocks would be cheapest way i think.
    =SOLD UP!=
      Milners do 25% uprated ones for around £45 & Procomp shocks are cheap as well.
        Try roughtrax for the shocks OR contact Tonyn
        Es3000's are oil and give a ride between the hard and soft setting
        Es9000's are Gas and much harder
        Note your hard /soft switch will no longer work
        Toyota ones are £100+
        www.daemon4x4.org
          Landcruiser springs are the way to go!!!
            And how big is the rear lift vince
            www.daemon4x4.org
              About 3"
              Or to put it another way, with 31" mud tyres, 38" from the ground to the wheel arch lip.
                About 3"
                If they are intrested you better work out how much it will cost to send your mod kit to France
                www.daemon4x4.org
                  If you read the first post, he hasn't got there yet and wants to sort out the rear suspension before he goes.
                  Pay attention dude!
                    Pay attention dude!
                    Sorry just looked at the location
                    OH well better go back to sleep
                    www.daemon4x4.org
                      hehehe!! and I'm going back out to the workshop to finish fitting my alarm.
                        Thanks,milners It Is!
                        As I Am Not Going To Horse It Up The Massif Central ,will The Hard Soft Button Still Work With The Procomps ?
                          No.
