turbo help
  • turbo help
    got a 2.4 dt the turbo sucks large amounts of fuel at 2000rpm.is there away to get the turbo to start sucking at about 2.5-3000 ish when its needed the mpg seems worse than mates 2.5 td disco or are there any other way of upping my mpg
    yeah - keep it at home
    not sure if you can reduce the boost,i guess theres a fairly easy way.
    Tim
      Sorry pal,
      2000 RPM is when the turbo kicks in, that how it is.......
      Run it on veg oil and your bills will divide by 3.
      I used to have a surf me!
        If you could alter the boost then your fuel economy would probably be worse than it is now. Your problems are elsewhere, not with the turbo. Fuel pump, injectors, air filter and a dozen other things can contribute to poor fuel economy. What is your MPG now and does the engine blow black smoke?
          fit an intercooler, that will help.
          or buy a skoda octavia diesel, they're economic.
            many thanks for your help
            many thanks found out what the problem is the new heads up the creek
