Hi all, long time reader 1st time poster
Hope your all ok, as i need some help/advice.......just purchased new front pipe for surf (2.4td 1989/90) and as per usual the last nut that connects the front pipe to the turbo (the one that is a complete nightmare to see) has rounded off and am really stuck trying to get it off any ideas? just to let you know have tried beating a smaller socket onto nut but where there is a heatshield on the front pipe it restricts the angle you can get onto the nut so i think that is the reason i have rounded it off
Is it possible to remove turbo at all with front pipe still attached enough so that i can maybe use oxy to heat nut and use molegrips to remove
any help or advice much appreicated
crasin
crasin
