whats a realistic time to change these?
torsion bars
If you have not done them before then allow about 1 1/2 hours. Give the bolts a good spraying with wd40 a couple of times before you are going to do them, also try and get a wire brush around the tops of the bolts before you undo themOriginally posted by slimwhats a realistic time to change these?
and a good greasing when you put them back together, and they are easier to do if you have a body lift.
I'm a custard donut monster
when i done the lift on my 2.4 and put uprated tor/bars on the were a sod to get into the front.in the end i hammered them in and once in they would come off and on no prob.I think its the drivers side that was a bit more awkward then the passenger sidehttps://www.facebook.com/groups/henpals/
