Help black engine smoke !!
  • Help black engine smoke !!
    Hi,
    was wonderinf if someone can help me ?
    When I pull off or rev the 2.4TD Hilux surf I get black smoke, I know it is a desiel but is there a way to stop it from smoking so much, I have seen on ebay that there are some guys selling a cure that stops the black clouds of smoke, but I am scepticle
    CVheers for any help JC
    Your right to be sceptical. Do a search on Black Smoke, you'll find all the info you need.
    Brian
      Black smoke help !!
      Hi,
      I did a search on the website for black smoke and it said nothing found, have you got a link for it ?
      JC
        Originally posted by taters02
        Hi,
        JC
        do a search on here for EGR mod and that will give you all the info you need and cost the price of a cable tie to do it
          Renew your air filter too, a dirty or clogged filter will cause black smoke, which is unburnt diesel.
          Oh, and here's the EGR modification.....
            Dont put so much veggie oil in the tank
            LOL
            Im not a gynacologist but ill have a look
              Heeeeeeeelllllllppppppppp !!
              I have done the EGR mod, does not seem to make much difference !!!
              It almost feels like she is mis-firring, the hilux is also quite flat power wise when pulling off.
              When you rev her it smokes clouds of black, and a friend said it sounds like the engine is misfirring, he reckons it could be an injector or it might be the pump !!!!
              The power is very flat and when I do put my foot down you get loads of black smoke pumping out the exhaust, it smells like diesel almost if it is running to rich !!
              Any help or advice would be much appreciated, you can email on [email protected]
              JC
                put the EGR back on to try and deduce whats goin on....
                Try redex for diesels to clear the carbon deposits on the injectors...just shove a full bottle in
                May need injectors reconditioned/new injector
                pump problem / timing off
                Gaz
