mines a 92 2.4 SSRX 54,000miles
Had hole in convaluted air hose between air filter and plastic turbo intake.
Took off old pipe and found oil pooling inside the plastic intake pipe!
Not streaming out but coating and pooling the inside of the pipe.
Fitted the new hose and started up-noticed a fair bit of blue smoke from exhaust.
Checked oil level- small drop about 1/5th of low-high level.
Checked coolant level- had to top up but only by 20-30mls.
Any ideas??
Turbo?
cylinder head?
Could be turbo seals- if it is ,does this mean a new turbo or can the seals be replaced.
As you can guess car mechanic is not my occupation!!
Any help would be greatly received.
Thanks
Any ideas??
Turbo?
cylinder head?
Thanks
