hub the $$$$
  • #16
    now sorted christ that was hard work,cheers lads the chisel did the job in the end the cone washers /ends looking like spring washers was the problem. but now off and sorted.
    but next prob were the hell do you get a socket that size to get the nut off. again.lol
    cheers oz.
    • #17
      cheers oz.
      well its a 54mm thin walled socket draper do sell them. There was a thread with the part number on hre somewhere!!!
      But you can do it with an hammer and chisel cause they arnt tight. just be carefull that you dont chip the bolt and loose the debris in the bearing/grease....
      CHEERS JOHN................
      • #18
        cheers john job for the morning.
        take note people check your pads as this is changing discs.on this model.
