fuelpump leak...aqgain
  • fuelpump leak...aqgain
    this time its from the stop solonoid end,there are 2 fuel hoses bolted into that end and it appears to be leaking from the block they are bolted to that is attached to the main part of the ip, can i remove this without taking the pump off? we have moved house and all tools are in storage and no garage for a few mths.
    Ta Ray
    hi ray i wouldnt advise removing the back of the pump in situ.the pump element are inside that casting and there are springs and shims that could easily fall off .a right pain to put back together when the pump is out of the engine bay let alone still on the engine.
    www.overfab.uk
