Hi guys and gals, I posted this question on the 6th of July but could not read the answers as it looks like there was a problem with the site. Could anyone who replied take the the trouble to do so again thanks. I have an L reg (1992) KZ130 3litre diesel surf. Ther Aircon has pressure on one side and not on the other. I think it is a faluty or stuck Expansion Block Valve. Does anyone know where I can get a replacement, a part number, how to replace it or anything else that might help. Thanks in advance Andrew
Aircon help
Originally posted by aldoDid you find somewhere to buy your expansion valve? I need one (I think). Also any tips on replacement?
My aircon was completely empty after my head change, and my mechanic re-gassed it and changed both valves, all for £60 cash.Rob
Still working for the man!
Had a similar problem with mine when I bought it 3 years ago. The offending part is usually the one under the n/s dash. Mine was fixed under warranty but I know the mobile guy who came out to fix it charged about £175 to re-gas, then remove, order and fit the part and re-gas. Been OK since though.Mike G
Originally posted by aldo£60!!!! What's his number?
Aren't these valves hidden behind the dash somewhere?
WOW that's a good deal.
Sorry, talking b0ll0x again, the valves he replaced were the two fill valves on/near the compressor.
Sorry to get your hopes up
Rob
Expansion Valve will be between the Receiver Drier and Evaporator.
http://www.autoaircon.co.za/technical.htm
Nev
