Good Morning
Taking the surf family truckster on vacation this year and want to give the coolant system a good flush and coolant change. Is there an engine drain plug on the 2.4 K plate surf and as im going to southern spain across the mountains is it beneficial to fit an earlier opening thremostat. also where can i get one from. 2nd question is how do you change the oil in the viscous fan and what oil do you put in it.
Many thanks in advance
Chris.
Chris.
