I have been trying to get my rad-fan to work, and upon checking the fuse box under the bonnet (next to the battery, that also contains a relay for the headlights and glow-plug fuse etc...) the relay for the rad-fan is missing. I assume there is supposed to be a relay here as the cover diagram says there should be.
If I short-circuit the 2 control pins (from the temp sender) the fan kicks in, but why would the relay be missing, or is this a common thing on jap Surfs?
Do I need a specific type/part number to replace it (ie. a genuine Toyota one) or can I get some generic part from Halfords or Maplin or suchlike?
thanks
James
thanks
James
 missing relay for rad fan?
