Oil catch Devises
  • Oil catch Devises
    Has anyone got any pictures of home made devises what parts you have used and or where you baught them from.
    How they or it fits from the rocker cover to air intake ( or not as the case may be ) and how fitted to engine bay?
    I need to get something sorted quickley and efectivley
    Thanks for the help in advance guys
    kev.
    Regards
    Kev.
    2.4 black beast
    c'mon lads looking for the same thing
      The search button is a wonderful thing.
      http://www.yotasurf.co.uk/forums/sho...oil+catch+tank
      Another one here in the engine mods section.
      http://www.hiluxsurf.net/index1.htm
        seen them andy, wanted to see some home made jobbies,
        there just down the road from me so at the worst..........
          Yeah c'mon guys,
          From what i have been reading this seems to be a commen problem so i thought a lot of you are already using home made catch cans/devises
          Regards
          Kev.
          2.4 black beast
            i just bolted a red bull can in there and run a hose from the breather into it, was only meant to be temp while attempting to diagnose turbo leak, but it does the job and will remain there for as long as it may!!
              At the moment i have used a cycle water bottle and tie wraped it to the fuel filter and run the pipe in with some wire wool.
              the airduct just has small piece of cork in it to blank it off.
              Regards
              Kev.
              2.4 black beast
                that should do the trick til something prettier can be found. ebay's worth a look
                if the bottle's plastic though you probably want to check it don't warp and split with the heat under a bonnet of a surf.
                  i'll keep an eye on it and replace as soon as i can.
                  Regards
                  Kev.
                  2.4 black beast
                    Hi This is what I did
                    http://www.hiluxsurf.co.uk/forums/sh...571#post144571
                    LN130 2LTE Auto
                      Took mine off today and put back to original place till i can find a better solution as it wasnt stopping the oil from making a bit of a mess to the inner wing
                      Regards
                      Kev.
                      2.4 black beast
                        Has nobody else got pic's of home made ones and all baught them instead.
                        Regards
                        Kev.
                        2.4 black beast
                          could'nt be bothered making one kev better off just buying one
                            Looks like i'll have to m8 lol
                            Regards
                            Kev.
                            2.4 black beast
                              Now where's the fun in that?
