After the usual cylinder head saga I've been treating my surf very carefully, but recently it's started making a strange noise at idle when cold - it's difficult to describe, not a squeak, not a thump, but more a sort of "aggressive-chirping"?
It's pretty loud for about 1 minute when the engine is really cold (first thing in the morning) - the truck idles at 700rpm but even the act of moving it backwards using the engine's torque (no throttle and at about 800-900rpm) decreases the noise significantly, and when you pull away (1000rpm +) it vanishes.
After about a minute at idle, or a few hundred meters driving (slowly) it is perfectly quiet again, and remains that way until the next cold start.
I fitted a new Stevo cylinder head + new water pump + cambelt, but not cambelt tensioners I don't think, unless Stevo supplies them as standard with his kit of bits (I can't remember if that was the case, it was last year) Also had new drive belts x 3. No air-con.
The thing that worries me is if it's a tensioner pulley on the way out, or something likely to damage the engine if it breaks. If it's an item that "fails-safe" (injector pump or something) I'm happy to wait until it goes.
How can I track it down? It doesn't last long enough to diagnose, and under the bonnet the noise is impossible to pin-point, but a friend seemed to think it was located on the passenger side of the engine-bay.
HELP PLEASE!!! I'm completely paranoid about it breaking!!
Are there any Surf-specialists around Newcastle that I could have listen to it?
thanks
James
thanks
James
