Can you tell the Difference ?
  • Can you tell the Difference ?
    Hi Guys & Girls I am having trouble accessing a site with "Error on Page"
    This site who supplied me a (Wrong) alternator so would you be so kind as to do me a favour & try it as I'm not sure it's me PC or their Website !!!! www.foreigncarspares.com[/URL]
    Judge for yourself the difference !!!!!
    Are they short sighted ??? or am I paranoid ?
    Jess
    Buncefield Burner
    their website loads up fine for me and err....if you sent them pics of yours and that what they gave you then they are short $$$$ed, i mean sighted.
    it's either sheer laziness or the 'we'll just send this and see if we get away with the quick cash' scenario.
      Thanks for that Logan, Sounds as tho I've solved one problem but still got me original one .......I'm Now !!!!!
      Jess
      Buncefield Burner
        the one with the label on is from an early landcruiser.
          Ta for that Terry, all Ineed now it Locate one that's not burnt out !!!!!
          Onwards & upwards.....................
          Jess
          Buncefield Burner
            Try Toyota, £145.00 fo a recon with 12 month warranty
            Rob
            Still working for the man!
              Thanks for that Bob, I got somethink arranged already but if that fails through I'll give it a Go !!!!!
              Jess
              Buncefield Burner
                The early models had a rear mounted vacuum pump as your pics show. The front mounted vacuum pump alternator may fit with a few mods to the oil lines. Have a look at the mounting points and pulley position on both to compare. Check the wiring as well. It may fit ?????
                  Thanks for that Nev, I have a few avenues to try first before I contemplate
                  this Mod
                  There's Always a Payback.... You just can't see it Comin !!!!
                  Buncefield Burner
