Loud clunking when parking on full right lock, I think from the right side but need to investigate to be sure. I assume it's the outer CV joint on the right side - rubber boot looks fine, so I suppose just at the end of its life.
The vehicle is due for MOT end of July, so I'll get it done early so I've time to replace it if it fails, but is it a tricky job to do?
I've had a squint under the wheel and it *looks* simple enough to get to, but will I need a ball-joint splitter or any other specialist tools? Also, how much is a new CV joint and where do I get one from, and what else do I need (new boot, grease etc..)???
thanks for your time
James
James
