injector seals?
  • injector seals?
    Just had my surf looked at by a mechanic regarding fuel leak. Apparently injector pump seals not the ones needed. I need ones for the 'injector itself'. Any idea where I get these from?
    You can get a set from Toyota, they arn't expensive. There is a small washer that goes down by the injector nozzle, a bigger one for the injector body in the head and its best to replace the leak-off pipe washers as well.
      Cheers!
      Don't suppose anybody has a link for parts like that?...
        Just stroll up your local Toyota dealer, give them your model number and chassis number from the data plate on the engine bulkhead.
        They'll even print out a expoded view of where they all go for you.
          Thanks
          Cheers for your help...
