The heater pipes that run to the rear heater silt up and stop the coolant flow to the rear . But first check the valve in the rear is not stuck shut , if it is OK you need to clear the pipes . Someone posted a thread saying they used the brake cable off their childs bike in a drill to clear the pipes .
Remember to refit the brake cable afterwoods
