help have oil leak has anyone any detailed engine shots as i know sweet fa. also i have either a farting or sucking noise just b4 turbo kicks in all i know is its near throttle cable end cos when i rev it inside engine bay i can hear it and my hand is $$$$ed in oil. any ideas
oil leak
Yep, thats common on most engines. It's engine air pressure mixed with oil vapour., that gets redirected back into the engine. Just pull it off and clean it out with turps or hot soapy water.
I've disconnected mine and blocked the hole in the plastic tube, and redirected a longer piece of hose into a plastic bottle, to catch the oil vapour. My truck doesn't smoke at all now!
p.s. Is your truck from the west Indies???? 'cos it says D turbo on the top.
